GTS-T or GTS25T ??
Guest Grant Mcdonald
 Share
Hi all i have just got a R33 94 model skyline , now ive been told that if it has GTS-T on the back then it is a RB20.
But mine has 2,5 on the top of the motor so should mine have GTS25T on the back , and i know its turbo i looked for that !:P:(
Grant,
The RB20DET was not a factory option in the R33, the R33 coupe weighs 1360kg, this is no doubt one reason why the R32's RB20DET engine was superseded by the half-a-litre-bigger RB25DET. The extra capacity squeezed out of the same RB block involved increasing bore and stroke to 86.0 x 71.7mm (up from 78.0 x 69.7mm respectively). However, the RB25 also features much larger inlet runners than the RB20, a vastly improved cylinder head, a larger (ceramic turbine) turbocharger and a marginally larger air-to-air intercooler. A relatively high 9.0:1 compression ratio!!
Skyline model - Engine codes
R30 - FJ20E,FJ20ET,CA18E,L20E,L20ET,LD28,LD20
R31 - RB20E,RB20ET,RB20DE,RB20DET
R32 - RB20DE,RB20E,RB20DET,RB25DE,RB26DETT
R33 - RB20E,RB25DE,RB25DET,RB26DETT
R34 - RB20E,RB25DE,RB25DET,RB26DETT
V35 - VQ25DD,VQ30DD,VQ35DE
http://www.meggala.com/r33main1.html
Meggala's site has allways got interesting info!
Also the easy way to tell what model you bought is by the Vin number on the compliance plate ie:
HR33 - RB20E - GTS ,GTS-S
ER33 - RB25DE - GTS25 ,GTS25-TypeS
ENR33 - RB25DE - GTS-4
ECR33 - RB25DET - GTS25t TypeM
BNR33 - RB26DETT - GT-R ,GT-R V Spec ,GT-R V Spec N1
MEGA
I think the sticker at the back of your car may have been replaced. Should say "GTS25t". The previous owner may have repainted the boot lid for some reason?
 Share
