Niigata / Maze Circuit
Guest Mashrock
i found a sticker the other day in my car. it was under my rollcage padding
i have had the car for over a year now. haha
it reads
Sunday racing cauce
Maze circuit
team nihonkai
there is a photo of it. but its a bit hard to get a photo of..
wonder if i can track down the owner. wouldnt mind some info on the car. or the engine and what they have done to it as there is lots of aftermarket shit and non standrad internals
https://www.sau.com.au/forums/topic/121824-niigata-maze-circuit/
a quick google search brought up the following:
this is from nagaoka (2nd biggest city in niigata) - orange FD is a nihonkai car
http://nagaoka.rgr.jp/ibent/dynamaite/index.html
http://www.medianetjapan.com/2/20/sport/ka...gotoibento.html
here's a site for the circuit:
http://members.aol.com/Mazecircuit/index.html
that might be a good starting point for investigation.
Guest Mashrock
so nihonkai mean what exactly?
my mate has done japanese for a bit but said it has many meanings.
i know nihon is japan. then i asked my friend and kai can mean shellfish. can mean levels in a building, and a gathering/party..
but once googled on that orange fd it came up team sea of japan..
the textbook japanese translation of nihonkai is the sea of japan. However the stickers meaning could mean anything
Although judging by the kanji the left 2 have no idea because of the photos angle the far right one appears as though it could be 海 beach, sea, ocean.
Also looking at one of Daioni`s links the orange FD with `Team 日本海` basically shows that theres some kind of race team called nihonkai
anyways :dry:
Edited by akeenan
Guest Mashrock
Certificate of originality on my rear window.
Peep the OG decal (anodized red/silver) that I got from the manager of the Nihonkai Maze Circuit in Japan. I saved it from our Tokyo Auto Salon excursion in January 1999. The most popular things to race at the Maze are motorcycles and hachirokus!!!
http://members.tripod.com/~teamcipher/doriftoREDae86.htm
from some honky website.. uhoh!
p.s. the photo didnt work but its at the bottom of link
Edited by Mashrock
yeah i'd say the previous owner probably bought the sticker at TAS or a shop to put on his cage cause he thought it looked cool, or maybe he had been to maze circuit? i would say there would be many of those stickers on peoples cars.
just get someone to have a look at your turbos and whip off your sump and that should give you some idea about what is on the car. or do you have the japanese registration (or de-registration) or auction sheet?
kai also means modified
so it could translate
Japan Modified
implying Japan Modified Car Club etc
and i don't know if you knew or not, but Maze would not be pronounced in the way we would say maze (not a puzzling series of turns designed to get you lost)
rather it would be pronounced MA - ZE
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
