thing i hate about the s2000 is that its tweaked to the max to get the power it claims, whereas most of the gtst's and gtrs even wrx's come undertunded out of the factory and do the same figuers at a similar price.
I like the way an s2000 looks but personally i wouldn't buy one. retspec to s2000 owners tho, and yes I generally was baggin civic, integra and prelude owners (unmodded ones).
If you look at my sig carefully... u'll notice that the top smiley never actually beats the bottom smiley lol its too busy wheelspinning that the bottom one gett to the finish line before the top one. Wierd but true.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
