Just a request for some time saving info re VIT on RB 25's We have just had our preliminary run on the dyno with our circuit car. Without going into details of spec, it charges its way toward 300rwkw (tire spin to be resolved), but initially it has a soft spot off boost.
What is the concensis of the variable advance. Retain v loose? what is the best base line inlet cam (standard) timing? Do non variable RB20 type cams fit the RB25?
We aren't real bright down here on the island... so any help appreciated.
I know I have moved to a Valiant... but still having Nissan fun too
TT
https://www.sau.com.au/forums/topic/122398-sos-to-all-rb25-tuning-gurus-skyd/
Hi mate, we run rb20 inlet cams in RB25 to eliminate vvt and run adjustable gear, i think it depends on what series engine though, i havnt tried it in series 2 yet. Only do this with big engines though, mild engines we retain the vvt and control it with the ecu. keeps a fat torque band through the mid range. depends on your application.
Hope this helps a little. Regards Stuart.
TT
TT
What cams you got in it?
:whistling: cheers :P
:( cheers :D
Standard at the minute, but I have suggested the boys put in a set of my Tomei PonCams (RB20 with adj wheels) but didn't know if it was possible.
I have been bombarded with questions and have no exposure to RB25... so thought rather than talk crap - ask first.
Thanks GC
GJ
Targa Tom
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
