IMMACULATE MY01 WRX
Why by standard for $22-23,000 when for a few more thousand you can driveaway in a car where everything has already been professionally fitted, with no expence spared, there is nothing more needed to be done to this wrx.
INTERIOR
Autometer Boost Guage & Pod
Short Shifter
Momo Gearknob
Subaru Mats
Subaru Rubber boot protector
Tint all-round
Quiktrac Tracking paid in full until April 07
EXTERIOR
Carbon Fibre STI MRT bonnet scoop
Fog Light Covers
Front Grille
Front lip also available just not installed
Genuine STI Headlights
Around 86,000kms
ENGINE & SUSPENSION
VF34 Turbo
MRT Fuel Rails
Ecutek
STI Injectors 550cc
AVO Catch Can
MRT Front Mount Intercooler
3 Iinch MRT Stainless Exhaust
Bosch 600HP Fuel Pump
Oddessey Battery
Slotted Front Rotors
Lighten Exceedy Clutch
Semi Organic Clutch
King Spring Super Lows
Strut Tower Braces
Whiteline Front & Rear Swaybars
Lightweight Oz Racing Supperleggero Rims
Its in immaculate condition both internally and externally
This car has been babied by both myself and the
previous owner, having had quite an amount of dollars put into it.
It is a very quick example of a bugeye, having had all improvements
fitted by MRT. All add-ons have been fitted in a professional nature taking performance and reliability to be driven daily into account. Its been tuned to achieve this. However more power atw is available if desired, As it is running a mild powered street tune (181kw atw) which is both economical and reliable.
This wagon has been regulary serviced with only the best every 5000kms,
$24999
Rego: AK95TW
Enquiries:
Phone- 0409288899
Email- [email protected]
Ive loaded some photos onto photobucket link is as follows
http://s47.photobucket.com/albums/f159/Robbo12345/
OK iv'e basically had it sold twice over the last two weeks, eventually being stuffed around both times in the end, finding out they couldnt get finance, the other after going out of my way to give them the details required over several days and dealing with an absolute barage of ridiculous questions, they tried to barter down on the before agreed price. Im am absolutely sick of timewasting idiots,
this car is as it looks, a my01 in excellent condition, and an absolute bargain.
Try and find the same model with this amount of extras for this price, im very confident it wont happen.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
