Hi guys i have for sale
Nissan s13 sr20det blacktop blown motor $400
block has hole through the side.
Nissan s13 ca18det manual gearbox conversion kit. $800
1x Nissan CA18DET Manual Gearbox 1x Manual Tailshaft 1x Manual Gearshifter 1x New Gearshifter Boot 1x New Clutch Fork Boot 2x Second Hand Flywheels 8x New Flywheel Bolts 1x Exedy Racing Clutch 1x Manual ECU 1x Manual Engine Loom 1x Manual Brake Pedal 1x Manual Clutch Pedal 1x Clutch Master & Slave Cylinders 1x Clutch Hydraulic Line 1x Manual Gearbox mount
1x Toyota 4age 20valve silver top $700
engine comes with all intake side
loom
no ecu or afm
call on 0401 494 339
loom
no ecu or afm
interested in the 4age engine can u pm me with more details!*
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
