Qld - Vg30det R31 Gts-x, Gt-r Brakes, Ems, Engineered Etc...
Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit. -
Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
