Another Price Drop. $13,000 with the wheels AS IS. $12,000 with standard R32 GTST wheels+good tyres. Get in and buy a nice looking and well-maintained car while you can. Petrol prices are dropping too so 2.0litre all the way!!! :spank:
Car is still for sale. Come on guys, one of the cleanest 32's going around. I just gave it a nice service... new plugs, filters, etc. New pod filter with cold air intake, new brake pads tomorrow. Car is well looked after
Edited by stawka
awesome looking 32. Just wandering if you could post up some pics of the engine bay and interior.
Cheers, Joel
Edited by jolz
  • 3 weeks later...
I cant actually post pics of the interior and engine bay as yet, my phone is playing up again. For those people that inquired about the car and i said "I will put in a new gearbox before i sell it because this one is stuffed"... Well, the job was done today. Car looks, sounds, and drives absolutely beautiful!
