Hi
Just bought the above & battery is shot (still has battery from Japan) & i need a replacement...
I HAVE DONE A SEARCH but all the posts i found were relating to coupe's with the battery in the boot & mine is in bonnet as its a sedan
What battery should i get that is better than std & will fit in original holder & attach to std terminals but wont cost an arm & a leg
Thanks
There's a group buy on Calcium batteries 550cca sealed items which would fit your R33 alright. you might need new clamps from repco or something though, it's quite a bit beefier but not *too* big.
Other than that, maybe odyssey or red top optimas.. but now u're talking a few hundred dollars.
How many CCA's is Std Battery & is terminal post std or small?
Also what do you guys think of these
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=377
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=379
Wanted this one but oo big to fit
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=365
Thanks
Edited by Noel
The ones you've listed are still lead-acid maintenance batteries. I'd imagine you could go anywhere for that sort of stuff (big w's, repco, supercheap) etc.
I can't really tell you what you need for your setup, but if you're looking at replacing the stock battery then you ought to be looking around the 330cca mark (well that's what was in my stock r34).
My setup is stock std mechanically & im running one amp & a 10" sub of a MP3 HU
imagine you have an alarm also? and you're not going to be running your system at full blast for extended periods of time with the engine switched off?
You'd get away with a 500cca lead type battery ... i had a similar setup in my previous beast (kicker 354xi amp, 12" rockford, stacker/hu, a few electronic gizmos) and i ran a similar battery without ever any startup problems.
The main reasons why you'd want to step up to a gel cell or fully sealed system are:
- often are deep cycle
- don't leak gas
- no maintenence
- can relocate into the boot
- often can be smaller than factory battery (talking only about the optimas and odysseys here)
- greater cranking capacity
downsides are of course ... cost.
Hope this helps you.
edit> in summary... don't be tight.. go the > 500cca lead-acid as bare minimum, go the gel cell if you need that overhead. :D
Edited by Howie
- don't leak gas
- no maintenence
problem is size...the one in there now is only 200mm Long, 130mm Wide & 190mm High with small terminal posts & i cant see anything bigger fitting in there at all & most batteries with a decent cca are at least 172mm wide & 239mm long
I don't know if they're easy to come by or not, but my mate who is an auto sparky put an AC Delco sealed lead-acid in mine - circa 550CCA - runs rings arounf the old 'Exide' that was in there when i bought it. Starts easier, and just plain starts after working on the car with the stereo on :D
Just thought id add my 2c.
NOTE ; It is also a very small battery, similar in dimension to what Noel described, small posts included.
Edited by pstanbis
it isn't essential for a sealed battery if it's up the front. Now that iv'e owned a skyline with a sealed battery, i would never go back thouguh.
no more acid spills, no more acid powder and rust everywhere etc.
You don't need such a massive battery. Before my stock battery died, the stock 330 cca battery worked wonders.
Hi
Thanks
I have a Rocket 452, 550 CCA, L 240mm W 174mm H 212mm. It fits alright. Longer brackets required. A point to note, if you want to change headlight bulbs, do so before you upgrade to a larger size battery :D
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
