You read my mind! I was thinking EXACTLY the same thing when I saw that..
I've got sparco's in my car and they would still wobble enough to make it really annoying to watch on video...
I might give it a go though... It's only $15 worth of aluminium and bolts. It may just work?
think of a way to cover the area effectively from welding splatter and i will weld up a couple for the shit bars in the back...
then can make up an adapter that attaches to that bar that can slide accross the m moujnt the camear where ever you want..
ok guys ive got half of my camera mounting system sorted. I've decided to stick with the bar across the "Holy cow" handles in the back seat.
I'm getting one fabricated out of 1in chome moly tube. For people who arent familiar with it, it's REALLY strong and rigid (good for stopping camera wobble), very light and fairly cheap.
As for mounting the camera to the bar, I've go some of these camera mounting gizmo's from http://www.gpsoz.com.au/ram.htm. They're a ball/mount type system that is adjustable through just about any direction you can think of and they are completely rigid when tightened up.. Like rigid to the point that I almost broke the camera before I could even move the joint when it's tightened up, and the joint still didnt move at all! They are seriously strong.. All up the bits cost me $60, but retail is $77 for what's pictured below. You can get them for heaps cheaper if you order from the US too..
The good thing about these is the amount of range of movement you can get. You can have it sitting further back looking forward at the road, or have the camera just peering over your shoulder so it can see the dash too.. Thats the only reason I went away from the static bar idea. no adjustment for the camera angles!
Pics..
Dissembled components:
Assembled components:
Attached to camera:
Range of movement:
Attach to your bar like this:
I'll post up some pics once I've gotten the chrome moly bar made up that you can mount the bracket to..
I expect the bar to cost about $100 to get fabricated, so total outlay for the camera mount will be about $160..
We use to mount are in the middle of the parcel shelf and worked really well and made up our own bracket out of metal got wicked footage or cruises and doesnt seem to mind the bumps and bolt it on were the child restraint bolts are or make a new hole I can bring our design to the photo shoot primordial if you want to see :whistling:
(I reckon I could find it we havent used it in awhile)
Great! Yeah I would love to see it Jess. The more ideas the better. Ill be at the photo shoot!
I was only worried with the fact that I've got chunky sparco seats that might block the view a bit. But i guess you would have the same thing with the GTR seats, so if you think it's the way to go it sounds like a good idea! I'll flag you down at the shoot :whistling:
Yep not a problem its nothing flash just a bit of metal really with some holes in it but works well I will go and try to find it now for you
We always had a pretty good view out of the lense but its all about fine tuning
The idea for the slivias is good.because the seats allow them to be mounted like that..
I found that you see to much of the dash at seat height,hence why mine is closer to the roof.Remove the rear veiw mirror if it is that high,cause it is virtually right in the centre of the picture.The seat really needs to be anchored to somthing,to stop shakeing occuring in the pic,whilst driving.
Another thing that could be done to my camera mount is slide for side adjustability..
Photo of my previous effort below. The trouble I found when seeking the best mounting location was ensuring I was capturing clear full vision over the shoulder (which dictated locating the camera high and rear....maybe why others have gone to the parcel shelf) I found the monopod was great for allowing me to not only easily adjust the camera height but also the camera pointed angle. I'd propose maybe some sort of combination of ideas with the headrest mount and a monopod?? The monopod could also extend to the floor to minimise any seat vibration or flex. Anyway .....just another idea.
Jon - looks awesome matey!
Jess - I remember you talking about that set up at Mt colah for the meet. Need to see it !! :)
Craig - How did your footage go with that set up for the skid pan day?Craved was saying there could have been some movement, any?
I use a suction type mounted to the rear window - although my camera is mega old and big its on a 30degree angle :)
Yeah but it doesnt work in the GTR only other cars but will bring it along getting it back this weekend ;)
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
