Well now that I don't have access to Victorian tradeplates, I can't slap it on the ae86 to drive it to track days n shit, so I need to tow the fcuker around... I can either molest the R32 or the A31, and being a family car the ceffy's gonna get the chop. Plus sometime down the track the widebody kit's goin on the R32 (eventually... lol) so I don't really want to have to chop it up to accomodate a towbar.
As the 86's a light rusty POS, it'd be a max of 1200kg (allowing 1000kg for the car and wheels and 200kg for the trailer). Can a RWD cef handle towing something like this?
Does anyone have a towbar on their cef? if so can you post some pics of the bar and where it mounts on the chassis? Also places where you can get em done, prefabbed kits if you know of any and costs if possible.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/
from http://www.towbarfactory.co.nz
NISSAN CEFIRO
1990 to 1994 SEDAN
Vehicle Chassis No: A31
Towbar Serial No: 175
TB Code: NIA31
Tow Weight (Non-Braked): 500
Tow Weight (Braked): 1500
might be an avenue.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2295069
NISSAN CEFIRO
1990 to 1994 SEDAN
TB Code: NIA31
might be an avenue.
your a ledgend shan. i've also been looking at the possibilities of this as ill need to tow a light weight sailing boat in the near future with my ceffy. Only thing i'm questioning is the rb20 in the ceffy, don't know how it will go with the low torque, will probably be spooling up non stop. :)
Let me know if u have any luck finding somewhere in australia that make them. I remember hearing something about the s13 tow bar possibly fitting, but again not sure on that.
Edited by skypy12
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2302026
yeah, I'm a bit concerned about the ceffy being RWD and towing a car. Might have to end up using the R32 as its AWD... both of them are RB20's though... plan is to run it at extremely low boost when towing.
Its easy enough to get a prefabbed on from NZ so I might not bother getting a custom one made up in oz. Its a bonus that the tow ball is removable, so I don't have to worry about it looking fugly.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303072
RWD is fine for towing. just make sure the weight balance of the trailer is right and it will be all sweet. eg don't put too much weight at the back of the trailer so it starts lifting the rear wheels of the car up if you know what i mean.
So getting parts in from NZ is generally a feasible option financially?
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303727
Trailer design and overall weight will play a major role. Especially when using a small (for towing) capacity engine. I think I read somewhere its ideal to have 80kg of weight pushing down on the ball. So dummy loading the vehicle, spares etc and marking where car sits for the best balance may be an idea.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303843
i was thinking of using a towing dolly instead of a trailer more recently, that way i don't have to worry about the weight balance etc, and also its cheaper at $400 for a brand new unit compared to a trailer. Only issue might be front bar having to be removed each time i tow the 86, and also i'll have to go a little slower than with a trailer. I'll also have to worry about the 86's wheels turning too i guess.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2316047
apparently the car being towed must be rego'd or something... pfft... sif. might end up with a front wheel a frame or something, apparently if a pair of wheels are off the ground then the car dosen't need rego.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2319383
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
