The above is from my old S15, but compatible with Nissan all PFCs of the same era.
Cord is shortened (now approx 1 meter long) and a new plug has been fitted. Otherwise in good working order and no scratches, no fading LCD screen etc
As there are a couple of different firmware versions of the Nissan HC, best to check with Apexi first.
Can COD for $220.
https://www.sau.com.au/forums/topic/12506-apexi-pfc-hand-controller-200/
Originally posted by Gav
Details:
Model Number : 415-X001
Serial : FCC3 010-00806
Working  well with new plug but shorter (80cm) cord.
just a quick question, why it's shorter and has a new plug? if it's in working order and you accept the offer then consider it's sold..
check your pm..
Should have explained why the shorter plug.
When I wrote off my S15, I couldn't get access to the plug - therefore had to cut the cord.
No damage what so ever to the HC, and I have tested it with the new plug on. Also easy to make up extension cord if needed using data cable and mini DIN 6 plugs available from Jaycar for a couple of bucks.
Only reason I'm selling is that it isn't compatible with the very old PFC that I have in my GTR.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
