OK - newbie questions coming up:
I'm thinking of upgrading from the standard steering wheel for my '93 R33 GTS, but I have no idea whether there is anything I should be looking out for in particular - is there anything that I need to make sure the new wheel has? Will I need anything additional to the wheel? Where would be the best place to take it to get fitted (preferably on the Sunny Coast), or is it fairly straight forward to do it yourself?
I've seen a few steering wheels on ebay, but I'm a bit worried they might be dodgy or just cheap crap - what's the major difference between cheap steering wheels (<$100) and the more expensive Momo or Sparco wheels (> $300)?
What are boss kits, and will I need one if I upgrade??
And finally, does this look like a crap steering wheel?
http://cgi.ebay.com.au/NEW-NISSAN-NISMO-T1...1QQcmdZViewItem
Thanks!!!
https://www.sau.com.au/forums/topic/125456-steering-wheels/
A boss kit is needed to bolt the wheel onto the steering column and allow the horn to still work, with the standard wheel the boss and the steering wheel are combined as one unit.
That one looks okayish, but a little garish for my tastes.. Simple designs look better IMO . Go with a momo / sparco or even a saas /autotechnica one from the likes of autobarn (or ebay). The more expensive ones are better made with higher quality materials, so paint wont flake off, rust, will be real leather etc... and also are engineered to design standards.
Important to note ADR10 relating to steering wheels, basically you can only go as small as 35cm in diameter as you still need to be able to see your gauges. I have a 32cm momo wheel and got defected for it. Its still on the car because i like it too much :)
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2316388
was an option on s1 r33 :)
Also, i dont know how they can fine you. Yes its illegal if the car originally had airbags but i'm not sure what year the law was bought in (ie: a 94 that had drivers airbag may be excempt anyway) but more to the point how wiill they know unless they can decipher the vin number to get the factory options or something?? (assuming you dont have a big red airbag warning light lit up on your dash too lol )
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2316411
Hey insomniac,
I get my 94 model 33 in under a month and i have been doing the research on steering wheels as well =) i also live on the coast, so we should go for a cruise! :)
So yeh, any import with a factory steering wheel fitted with an airbag that is replaced with a steering wheel without is grounds for a defect.
However, i dont like the 93/94 model steering wheels in the 33's, so mine is coming off and ill be taking the risk :)
Same with the gear knob.
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2317824
Hey insomniac,
I get my 94 model 33 in under a month and i have been doing the research on steering wheels as well =) i also live on the coast, so we should go for a cruise! :(
No problem Sambo - let me know when you're ready to go and we'll sort something out. I know how excited you get when you first receive your new toy! Be prepared for lotsa money being poured into it though! :D
Where abouts on the coast are ya?
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2317926
Yeh man, ever since the car has been paid for ive been checking my watch every 5 minutes hey >.< !!
Im at the very top of buderim, so its not far to jump on the motorway or down the back way through maroochydore for a cruise :D
Can't wait man :(
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2317947
changing the steering wheel is something you can do yourself, with usually a ratchet and screwdriver
What the difference between cheap and expensive wheels? usually, just a brand name. I bought a $100 wheen new from ebay - its leather and alloy and built strong. no, it doesn't have a brand name, but who cares? see attached pic...
what's a boss kit?
well its basically a piece of metal that, on one end, bolts to your particular model of car. on the other end, it has a series of holes that bolt up to almost any aftermarket steering wheel. So you need on specific for your car, but any universal steering wheel will work
In summary: buy a cheap ebay wheel if its new from an ebay store and you will have no problems at all!
my wheel: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MEWN:IT
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2318048
there's a sensor on the steerign column that is moved when the steering wheel is moved.. so hicas knows where you're turning the steerign wheel and can assist you appropriately by turning the rear wheels in the correct direction
have changed my wheel a couple of time but never seen it, must be behind the boss.
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2318259
yeah behind the boss...
pull off your aftermarket wheel tyo reveal the boss
pull off the boss (remove the large inner nut) and reveal 2 items
1 * horn plug with a wire that runs up to your horn
1 * hicas sensor that slides into the boss kit to be turned when the steering wheel turns
https://www.sau.com.au/forums/topic/125456-steering-wheels/#findComment-2318276
