Hi Guys,
My front discs are running low on the GTR, i will need to get new discs. Car will be used for track/street use. What discs do you guys recommend to buy. A rough price estimate would be great. I had just purchased the Ferodo P2500's as well.
Thanks,
Husnu (Hus).
https://www.sau.com.au/forums/topic/125545-discs-for-r33-gtr/
Yeah thats what i'm leaning towards. 5000 Series would be great, but i guess a lot more in price.
Isn't the only real difference between 5000 and 4000 that the 5000 come with those hats, so you can replace the disc a bit cheaper?
As you say the hats are seperate so the disc is a floating disc on the 5000's. This also allows far better heat dissipation as well as replacing only the rotor and bolts as opposed to the entire disc and hat.
Big tip is (if using the 4000's), never get the cross drilled if you are taking them onto the track.
I had some put on (at the recommendation of the supplier) and shattered both front rotors on my second run. 5000's have been pretty good so far.
I'll have to shop around and see the best price available on the 5000's. Ferni, i remember u mentioned some good deals with UAS. Any chance of getting a price on the 5000's mate?
Or if anyone else knows of any cheap suppliers for them.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
