LAST POSTING. DON'T MISSED OUT!!
$800ono
264 cams with 8.5mm lift For RB25DET series 1 and 2.
Located near Liverpool NSW.
0423 736 279
I've seen these cams on an R33 they sound so damn good! and yet good for everyday road and weekend drags too!...I just don't understand why people are not so keen with it. It's so hard finding this duration with this lifts on a HKS cams.
It's a straight Bolt on people!!
Unfortunately there is no HKS sign on there except for the end of the Lobe indicating the duration and lifts.
https://www.sau.com.au/forums/topic/126925-bargain-hks-camshafts-for-rb25det/
Are these second hand, and does the head require modifications other than valve springs and cam gears?
Yes these are 2nd hand..But i don't see any different in Brand new or 2nd hand when it comes to camshafts as long as the duration is there it will do it's job.
And no head modification required as these are straight bolt on because they are 8.5mm lifts only. It will add an extra 20-30kw easily to your stock engine.
These are rare and i don't think HKS make them anymore. Usually at 264 they have a higher lifts of around 9.0mm+ or something which requires you to modify your RB25 head to solid lifters.
Edited by Deceeve
S1 and S2 have different CAS drives, which one do these cams fit?
:D cheers ;)
I've been trying to get a hold of the person i bought these from as to whether it's for a series 1 or 2.
But i've rung a few workshops and they say it will able to fit either by change the angel sensor on them. So if it's for a series 1 and you're trying to fit a series 2 then get the angle sensor from series 1.
Which shouldn't be much an expensive job to do.
Although at the end of the cams there is one round pins sticking out..not sure if that gives any indication if it's a series 1 or 2 or not
  • 3 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
