  • Replies 43
Posted Images
car could easily run high 11's.. was running low 12's but that is on some crappy rubber and very shit launches.. only been out there once..
with semi slicks and the right launch, it could easily get into 11's
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2396444
yeah it is at the wheels.. yeah dyno sheets i will show you.. it was tuned by unigroup so they well i think are the best tuners in sydney, and tuned it safely.. will scan dyno sheet in for you
been holding up perfectly fine for 8 months no hiccups or anything..
the blocks are solid
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2402993
$200 Spotters fee for whoever refers the car to friends and they go through with the sale.
This is free cash for whoever refers their friends to buy their car.
So go on tell your freinds and get 200 bucks for free if they buy the car
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414010
peak of 1.2 bar which is 17 psi. So it normally sits at 1.2 - 1.3 bar to get that much power, with the hi flow turbos they are all not the same, so Unigroup have told me that i have got one which is pulling more punch since they have tuned it safely and reduced the power just in case, but it could easily go to 270rkw they say.
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414648
Keeper: splitfires does the job so well
and i recapped the plugs it .69 but that is all
splitfire helped so much..
dazz: side skirts came with car when my mate purchased these ages ago, so i assume these come from japan
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2462410
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
