  • Replies 43
Posted Images
car could easily run high 11's.. was running low 12's but that is on some crappy rubber and very shit launches.. only been out there once..
with semi slicks and the right launch, it could easily get into 11's
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2396444
yeah it is at the wheels.. yeah dyno sheets i will show you.. it was tuned by unigroup so they well i think are the best tuners in sydney, and tuned it safely.. will scan dyno sheet in for you
been holding up perfectly fine for 8 months no hiccups or anything..
the blocks are solid
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2402993
$200 Spotters fee for whoever refers the car to friends and they go through with the sale.
This is free cash for whoever refers their friends to buy their car.
So go on tell your freinds and get 200 bucks for free if they buy the car
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414010
peak of 1.2 bar which is 17 psi. So it normally sits at 1.2 - 1.3 bar to get that much power, with the hi flow turbos they are all not the same, so Unigroup have told me that i have got one which is pulling more punch since they have tuned it safely and reduced the power just in case, but it could easily go to 270rkw they say.
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414648
Keeper: splitfires does the job so well
and i recapped the plugs it .69 but that is all
splitfire helped so much..
dazz: side skirts came with car when my mate purchased these ages ago, so i assume these come from japan
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2462410
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
