  • Replies 43
Posted Images
car could easily run high 11's.. was running low 12's but that is on some crappy rubber and very shit launches.. only been out there once..
with semi slicks and the right launch, it could easily get into 11's
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2396444
yeah it is at the wheels.. yeah dyno sheets i will show you.. it was tuned by unigroup so they well i think are the best tuners in sydney, and tuned it safely.. will scan dyno sheet in for you
been holding up perfectly fine for 8 months no hiccups or anything..
the blocks are solid
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2402993
$200 Spotters fee for whoever refers the car to friends and they go through with the sale.
This is free cash for whoever refers their friends to buy their car.
So go on tell your freinds and get 200 bucks for free if they buy the car
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414010
peak of 1.2 bar which is 17 psi. So it normally sits at 1.2 - 1.3 bar to get that much power, with the hi flow turbos they are all not the same, so Unigroup have told me that i have got one which is pulling more punch since they have tuned it safely and reduced the power just in case, but it could easily go to 270rkw they say.
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2414648
Keeper: splitfires does the job so well
and i recapped the plugs it .69 but that is all
splitfire helped so much..
dazz: side skirts came with car when my mate purchased these ages ago, so i assume these come from japan
https://www.sau.com.au/forums/topic/127054-sold/page/2/#findComment-2462410
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
