Just spoke to my mechanic, and he has had NO trouble tunning the idle on an RB26. The placement of the vaccum/boost hose on the plenum is critical. He plumbs it into an existing nipple on the bottom of the plenum, as he beleives the MAP is more stable there.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2365759
Wait until you get some decent sized cams.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2365934
  • 4 weeks later...
Hey AL, was wondering where you got your Wolf 3D version 4 from and did they tune it???? ;)
I purchased the ecu from EAS Performance, Airport West (PM me for more details) and yes they have done all the tunning on the car. It is now running smoothly and am very happy with the results ;)
If you live in the East, go to Sabaddin (PM silva33 for address). He is also a Wolf distributor and have seen some very good tunes on various cars and ecu's.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2433167
I have never seen a problem in our workshop with the Version 4 controling multiple throttle bodies even with very large cams.
The V500 is an awsome ECU, It can even control costant changing cam timing. The list of things it can do is almost endless. Just wait until you see the software :ninja:
Dont blame the ECU if you cant set it up properly like alot of workshops do!
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2435212
The V500 is an awsome ECU, It can even control costant changing cam timing. The list of things it can do is almost endless. Just wait until you see the software :huh:
The v500 software is downloadable from www.wolfems.com.au so check it out. Has heaps of adjustments. The datalogging isn't that great though. It looks like they used the v500 software to make the v400 just by removing some features. That's probably why it crashes a lot with a v4 ecu and the datalogging doesn't work correctly.
The v500 does look like a great ecu.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2454753
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
