Hey ladies and gents, looking to offload this boost controller as I've bought a replacement. It currently has a glitch where its not running the original boost pressure it used to, traced it to the solenoids I almost 100% sure, bleeding pressure, even when the controller is switched off. Works as is and seems to work quite well but I don't want to risk damage in case of a spike or what not as im running a pretty 'on the edge' tune.
Issue started about 2 months ago, where base boost with controller in the loop rose from 7psi to 10psi. Had marks for my 'safe tune' on the controller unit which is now useless to me as I had to wind the knob down for it to run near correct boost. From face appearance (I cant confirm, just looks exactly identical, the solenoid box itself I talk of) the twin solenoid setup is exactly the same as that used in the newer Blitz Dual SBC Spec R pictured here : http://www.blitz-uk.co.uk/images/sbcspecr.jpg so you if you could just source the solenoid box, or even just the solenoids, then its quite an easy task to swap them over (I've opened up the solenoid box and applied some silicon to wherever I could see joins on the 2 solenoids to make sure there were no external leaks - didn't help, so obviously one of the solenoids is leaking internally)
Difference from the unit in the picture and the older Blitz Twin Solenoid I have for sale is that there is no digital 'boost gauge' type unit on the controller, and there is also an extra component, guess its the brains of the unit, where the controller is connected to, as well as a vacuum line and loom going off to the solenoid box that you position in the engine bay. Has adjustability for sensitivity and switch for use for both actuator and wastegate setups.
Anyway, as I said, it works as is and when setup the boost doesn't seem to be all over the place (ie, its continually holding the same boost when setup the same, not one minute 10psi, next minute 15psi etc etc) but I cant promise that that'll be the deal in the long time (solenoid could start bleeding more air). Has two adustable levels and a button to switch between the Hi and Lo settings, as well as power button to turn it off altogether (although as I said, it currently wont run 'base' boost even with the controller turned off, ie whatever the wastegate or external gate runs as standard, which I believe is ~5 or 7psi in MR2s with stock wastegate actuator.)
Anyhow, would like $150 ONO but throw me an offer. I'll take pics of the unit once I get my hands on the eboost 2 and remove this unit.
Edited by -Totenkopf-
Bump, this may not even be faulty at all. Seem to have similar issues with the eboost as well. Admittedly its not setup correctly yet but I'll keep you in touch with the results.
Ah, appears it wasn't the boost controller playing up at all, the diaphram in my external gate has splits in it :miner:
As such, im pretty sure this is 100% working and without fault. Adjusting price to $200 ono in light of this new info.
Anyone interested? Will try get ahold of a digital camera tomorrow and take some happy snaps.
It comes with:
Controller unit.
Little 'brain' box I guess you'd call it.
Vacuum line to from above mentioned box to engine bay, with a T piece on that end.
Solenoid box.
Loom to connect 'brain' box to the solenoid box and also power and ground connections (these will probably need shortening for most cars, it was pulled from an MR2, and as such, wiring is a fair amount longer then your standard front engined car).
Anyhow, pics to come. I'll take some pics of the external gate diaphram whilst im at it to show you that im not having you on, unfortunately for me :rofl:
Ah, appears it wasn't the boost controller playing up at all, the diaphram in my external gate has splits in it >_<
It comes with:
Controller unit.
Solenoid box.
Anyhow, pics to come. I'll take some pics of the external gate diaphram whilst im at it to show you that im not having you on, unfortunately for me :mad:
Pics postponed till tomorrow for all that requested them. Had to attend a birthday party today of a family member, as such didn't have time to get around and borrow a digi cam.
Some pics:
Thanks.
James.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
