Here is a quick few basic answers to the 06' CDSN Inc Street Car Series Show - Sponsored By Arnold's Advanced Tyre Centre & Rocksure Insurance:
11 November 06 - Gates @ Showgrounds open from around 9am, Lock down for Competitors is 11:30am (Inc Sound Off Cars) -
Price= Static Display (Only) = $10, Sound Off (Only) =$15 (Run By Autobarn Rockhampton), or both Static & Sound-Off =$20.
For More Info eg: Trophy Categories & Sponsors click this Link -
http://cdsninc.net/forum/viewforum.php?f=40
Well I hope she wasnt the one who after I filled in her paperwork decided to watch the sun go down and missed thier start on our stage, tell you what I WAS NOT HAPPY, her driver came running up yelling out, "Why are the guys who were behind us starting before us." and I said, "Cause your dumb bloody navigator didnt make it up to the staging area in time and now you'll just have to wait!"
  • 1 month later...
Hi
How many of us SAUers are in Central Queensland??
Thinking about joining the SAU QLD Chapter...but curious as to numbers and cruises (frequency/numbers)
saw a few seem to be in Rocky...Im in Gladstone
RellikZephyr
EDIT:
i would be interested
Edited by RellikZephyr
Yeah the club doesnt do anything outside SEQLD because that is where all the members are.
Which is why I joined CDSN, they are local and run events for locals.
If you are interested then register with cdsn and vote Yes in that link I posted above :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
