The locked diff comment reminded me of a mate who modified the diff of his old corolla.
He some how welded it so that it was a one wheel drive.
After that he was able to step on the brake at any speed in any gear and instantly smoke it.
Had it down the burn out comp and won one of the years also.
The problem with one wheel drive is the slightest incline and the thing gets bogged as you try to take off, simply sits there and spins. Awesome fun.
1 wheel drive genrally happens when you snap a weld with having a locker.. 1 wheel cant seem to get traction no matter the powerplant.
in fact deluxe i might be able to find a small side draught for you? mate has all sorts from when he had a to4'd 179 in a hd holden.
Yeh nice the old lockers in my mates old Cilica used to go thru Axles like there was no tomorrow.
Oh and Jase if there was a side draught webber there to be used that would be sweet as they don't seem to be easy to find these days, You think it'll go straight on?
I think thats what he's done.. welded up just single spinner for the burnout comp. He eventually became annoyed with it and dropped in a normal diff again. He wasn't keen on lockers, especially as it was gutless. :mellow:
im not to shure if there is a webber there, ill have to check tomorrow, from memory there is a dellorto and a stromberg.
either would be totaly sufficiant for what you want, its just a matter of fabricating the necisary manifolds ect..
pretty straight forward stuff.. you will have a hell of a time making the thing run right.
is a factory t25 t28 wastegated at 7-8 psi?
Be careful, the pistons are like porcelain, they blow ringlands at any time. You
will have to limit it to 80rwkw and keep boost under 10psi. Shaun ex apprentice built one
using my old parts (cam, turbo, intercooler) on a 5 k , it made 100rwkw on 12psi.
Mine made 156rwkw on pump fuel:), arguably the worlds most powerful toyota K motor.
LOL yeh nice..... nothings has really progressed apart from some C__T cutting me off 2 days ago and now i'm up for a new bummper, lights(well U Pull it) and some handy pannel work to be done by myself, but apart from that i was thinking of only putting on a webber and exhaust and maybe just keep it reliable.
But 156kw out of a 5k would have been some REAL NICE fun!
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
