My father told me just recently about a corporate weekend he was running. His boss asked him if he would like to go for a drive after the days workshops etc. He said sure, as the guy is his boss, and they proceeded to climb in his MY01 rex. As my father retold the story, I could hear the fear in his voice. :P He said he nearly needed to clean himself. The guy took him on some weird backroads. He said at one point he looked over, and the speedo was reading about 170. Moral of the story? drive quick enough to remind yourself you are alive.
https://www.sau.com.au/forums/topic/13-scary/
the speedo was reading about 170. Moral of the story? drive quick enough to remind yourself you are alive.[/quote:4650d16cec]
I like that moral. I've only ever been past 170 twice, as I've never been on a track, and I tell you it's f*****g scary on a Sydney road. I clocked my car, heading southbound from the domestic airport and I never knew how bumpy this road was until then. It's a fairly new road but going that fast you tend to feel more of its flaws. Don't think I'll be doing that again. :mrgreen:
https://www.sau.com.au/forums/topic/13-scary/#findComment-205
Where in Europe? Were you born there? How do the roads compare to Sydney ones?
I'm from Europe too but I was too young to remember most things. My dad used to tell me stories of when he used to go to Germany. Those autobahns sound cool. You're doing 180 and the steering wheel is starting to shake and all of a sudden whoooosh. A BMW just passes you with no effort at all.
https://www.sau.com.au/forums/topic/13-scary/#findComment-207
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
