Gb: Brand New Z32 Afm's - $330.00 Each
  • Replies 117
Keen on one with adapter, but a couple of q's
Would I need a tuner to hook up the plug, or can it be just adapted to the existing plug? Also, do I need to retune my ECU?
You will require an aftermarket ECU.
The Tomei plug would need to be soldered in to replace the factory plug and wiring - Simple job for a workshop
Hmm if the groupbuy was going to end any sooner, I would put myself in,
My AFM died on the R34 and need one urgent.
As soon as we have 10 takers, which as this rate could be by the end of this week, we can start taking payments and sending the AFM's out.
Stock is ready to roll once we have the minimum of 10 orders ready
Darn, if I had waited 2 more weeks I would have paid a bit less. I paid $446 for my Z32AFM+plug delivered from Japan to my door. Just got them last week.
Yea as Nick said any workshop can do it.
or try doing it yourself.. See this DIY tut: http://www.skylinesaustralia.com/forums/in...howtopic=116520
You will need aftermarket ecu and have the maps changed abit.
Nick FYI I DO NOT need a plug.
Tropper: Did you want me to pick up yours if/when Im down at Justjap since you live pretty close to me.? PM me.
Thanks guys, _8OO5TED_ you are now on the list.
Stay tuned for further updates later in the day today including instructions on how payment can be made.
Nick
Correct me if im wrong but pretty sure you dont need a full stand alone ecu just a piggy back will be fine ie: SAFC etc...
From what i understand anyway
I believe you will require an aftermarket ECU, however if in doubt please consult your workshop.
Hi guys, the AFM's and plugs are ready to go.
Each one of you who has confirmed you are in will recieve a pm shortly with direct deposit payment instructions.
Nick
Payment instructions have been sent via pm to the following people:
- FLYSLY
- rbsilvia
- Crack
- d00dz
- danoz
- AcoustiK
- _8OO5TED_
Please be prompt with your payments to keep things running smoothly.
Any questions? Just ask
Nick
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
