skidkid Posted August 15, 2006 Share Posted August 15, 2006 I am looking at buying an early 300ZX VG30t (2 cam engine) for our class 5 offroad car and am seeking info. Has anybody used one of these engines with reliability and success? What manual g/box and b/housing do they use? Where can I buy a Navara front entry inlet man.? Has anybody got a std computer and eng. loom? How much boost will std engine take with correct tune? Anybody built replacement turbo exhaust manifolds? Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/ Share on other sites More sharing options...
SteveL Posted August 15, 2006 Share Posted August 15, 2006 (edited) Check out http://z31.com/ These cars are fairly heavy and stock have the same output as VLT (150kW at the flywheel). Be warned that they are renowned for spontaneously bursting into flames.....heat buid-up in the 'V' of the engine causes fuel leaks and, well, instant BBQ. Nissan did a recall in the US to fix the problem, but never admitted to anything in Oz even tho many owners have experienced 'the problem'. Gearbox in the stock Z31T is more-or-less the same as RB20DET type, but fortunately the gearbox in RWD Navara is as strong as the RB25DET type and will bolt up. An option for upgrade is VG30DET from Cima....190kW stock, but might not be allowed for your class. Suspension setup is largely the same as Datto 1600 and 280ZX (+ R30 Skyline, etc)....semi-trailing arms at the rear plus mac struts up front. Edited August 15, 2006 by SteveL Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2412982 Share on other sites More sharing options...
Slide Posted August 15, 2006 Share Posted August 15, 2006 I havnt been envolved in Off Road racing for a couple of years but if you want to enter class 5 in a full body car and you are changing the engine, use a lexus 4ltr v8 Reliability of these engines regardles of abuse is amazing. As far as im aware the origional body shape must remain but everything else as long as they remain rwd can be changed. I used to follow this car around being attatched somewhat to the family. Class 1 with a Stock Toyota 3SGTE Its awesome fun What car do you plan on using? Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2413389 Share on other sites More sharing options...
2rismo Posted August 15, 2006 Share Posted August 15, 2006 Oh BABY that looks like fun!!! Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2413454 Share on other sites More sharing options...
skidkid Posted August 17, 2006 Author Share Posted August 17, 2006 (edited) We bought a 120y 2 door that was built for class 5, years ago. It has a recessed fire wall. It has a 180b diff assembly in it. We are going to get it going with a hotty L18 and 5 speed but I am liking the idea of a VG30t. Edited August 17, 2006 by skidkid Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2418431 Share on other sites More sharing options...
skidkid Posted August 18, 2006 Author Share Posted August 18, 2006 Anybody know of any vg30t powered buggies or offroad cars? Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2421484 Share on other sites More sharing options...
MANWHORE Posted August 18, 2006 Share Posted August 18, 2006 just a suggestion, but how much power do you need? Those vg30s are clumsy and heavy. How about a ca18 or sr20? Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2421617 Share on other sites More sharing options...
Slide Posted August 20, 2006 Share Posted August 20, 2006 Anybody know of any vg30t powered buggies or offroad cars? I have never seen nor heard of one being used. You would probably be the first. But the weight of this engine in a 120Y would be bad for pretty much all soft tracks and i wouldnt think it would do you any favours. It would be definately more suited to another car/buggy Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2423500 Share on other sites More sharing options...
skidkid Posted August 20, 2006 Author Share Posted August 20, 2006 Something like a Navara? Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2423692 Share on other sites More sharing options...
Slide Posted August 21, 2006 Share Posted August 21, 2006 It would be a lot more suitabe with suspension available and weight distribution. You also wont have to modify the firewall and sacrifice cabin space to fit it in lol Aaron Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2426675 Share on other sites More sharing options...
skidkid Posted August 21, 2006 Author Share Posted August 21, 2006 Slide, Are you able to give any tips on budget building some long travel (8"- 12") Macpherson strut front suspension. The car has Bluebird struts in it at the moment. Or do we need to fit some a-arm / vw front sus.? Can you provide any tips/ measurments of lenghts, angles, shock mount position when building a-arm? With the 180b rear what sort of angle can you run on the shafts? With the car sitting still what sort of cambers do we want? Cheers, Jason. Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2426810 Share on other sites More sharing options...
Slide Posted August 22, 2006 Share Posted August 22, 2006 I dont really have any technical knowledge of your particular class but if you are going to be envolved with SORRA (Sydney Off Road Racing Association) then post up in the forums or get out to an event but places like Gondawindi and such require some good suspension setups to cope with the likes of this sort of air time. Even with these i have seen strut towers come clean out of the bonnet so go nuts with the support welding. Start here http://www.offroadracing.com.au/ http://www.offroadracing.com.au/links.htm If you currently attend a few events just go and speak with some Class 5 people. There used to be two guys from Dondinalong i think with 2 Datsuns but im sure both of them have been retired now for the tube Buggy setup. Because you dont want this to happen. Link to comment https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2430445 Share on other sites More sharing options...
