I have 10 full sets. $70 each set.
These are all brand new....not second hand. Will post to anywhere in Oz for this price
One set comprises 4 bushes that are two different sizes. These greatly inhance the rear stiffness of the vehicle and in most cases will improve traction and 1/4 mile times by up to 1 second. Great also for drifting as the new stiffer rear end will tend to slide more easily once traction has been broken.
https://www.sau.com.au/forums/topic/130544-pineapples/
do you have to remove the cradle to fit these or do you just lower it?
Depends on what configuration you go for?
You can slit the bushes and slot them in by loosening the subframe.
Or do it the hard way and drop the hole subframe installing the bushes without sliting them.
https://www.sau.com.au/forums/topic/130544-pineapples/#findComment-2417437
You can just remove one half at a time....to install literally takes about 10 minutes, so to answer you question, you can just lower it.
wat brand are these? where u located?
They are superpro and I am located in Brisbane's south
Got any pics? Alloy or Polyurethane?
I will get pics tomorrow ( I keep them at work )...and they are Polyurethane
I will try to sort out some installation instructions and post them up
https://www.sau.com.au/forums/topic/130544-pineapples/#findComment-2418857
  • 3 weeks later...
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
