Zahos Posted August 18, 2006 Share Posted August 18, 2006 I recently had some injectors cleaned and they were flow tested at 3 controlled pulse rates (I was expecting to get a static test done). The results were consistant accross all 6 injectors: at 250kPa (~36 psi) -------------------- 40 cc/min @ 2.5 ms 62 cc/min @ 10 ms 155 cc/min @ 1000 ms (how does that work out, as 1000ms = 1 sec??) ------------------------------------ at 350kPa (~50 psi) -------------------- 44 cc/min @ 2.5 ms 68 cc/min @ 10 ms 190 cc/min @ 1000 ms As injectors are rated at a static flow rate (100% duty cycle), is there any way I can convert those figures above into a static flow rate? The last test (@ each pressure) says 1000 m/sec which equals 1 sec. Does this mean it was a static flow test, or are these figures at 50% duty cycle, meaning 1sec on / 1 sec off??? Z Link to comment https://www.sau.com.au/forums/topic/130766-injector-flow-rate-at-controlled-pulse-width-not-static-test/ Share on other sites More sharing options...
Zahos Posted August 22, 2006 Author Share Posted August 22, 2006 BUMP Anyone? Link to comment https://www.sau.com.au/forums/topic/130766-injector-flow-rate-at-controlled-pulse-width-not-static-test/#findComment-2429397 Share on other sites More sharing options...
MerlinTheHapyPig Posted August 22, 2006 Share Posted August 22, 2006 why don't you ask the place who did the test? Link to comment https://www.sau.com.au/forums/topic/130766-injector-flow-rate-at-controlled-pulse-width-not-static-test/#findComment-2429739 Share on other sites More sharing options...
Zahos Posted August 22, 2006 Author Share Posted August 22, 2006 why don't you ask the place who did the test? I did ask him, he wasn't sure. He has the equipment to test it, and he just follows instructions, and jots down the readings.... Just checking to see if anyone has had a similar report, as they might have known what it meant. Link to comment https://www.sau.com.au/forums/topic/130766-injector-flow-rate-at-controlled-pulse-width-not-static-test/#findComment-2430821 Share on other sites More sharing options...
