Hello,
I have a set of BRAND NEW Garrett 707160-5 Turbos(Equivalent to HKS2530's) Rated at 350hp each with
supporting modes, actuators attached.
These are a direct bolt on replacement on any GTR.
I am asking $2750 for both and am able to deliver for free in Melb. Metropolitan Areas.
PM or Email me if anyone is interested.
Thanks
Tekin :mad:
SOLD SOLD SOLD SOLD SOLD SOLD SOLD
https://www.sau.com.au/forums/topic/130882-garrett-turbos/
Hello,
Thanks
Tekin :)
PRICE DROP $2700 :laugh:
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2422439
Hello,
Thanks
Tekin :D
PRICE DROP $2650.00 :)
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2423537
$2550 no more no less :O
For an extra $300 you can have a RB26 Manifold set :) (stainless Steel)Tune Agent Low Mount
Come on guys $2850 for both sets, Manifold and Turbos.
All Brand New in Boxes....Expect to pay over 3kPlus from Suppliers.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429399
as i now have no licence i was thinking of pulling of turbos and replacing?would these turbos be ok with everything stock besides ur usual exhaust filter mods.... how laggy are they????
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429611
Lag is slighly higher than the factory units.
You need a set of hks dump pipes to get them to spool up quicker, and might need new braided oil lines,
smaller than original to protect the turbo's from over supply(These are ball-bearing and need less oil through them).
If you are concerned about the lag, get a D-Jetro Power fc set up and lag will be in the past.
Slight mods such as air intake and exhaust(3") would have a great affect when these are installed.
You would need to get it tuned after fitting.You need to tighten the actuators to set the boost up if you do not want to use a boost controller.Do a search to see results on these turbo's.
Hope I have been some help.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429654
For an extra $300 you can have a RB26 Manifold set :P (stainless Steel)Tune Agent Low Mount
These come with a waranty guys.......$2850 with manifolds , all new.
Expect to pay $3300 plus.....come on.
You can pick up too...how good is that.
Cheers :)
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2433415
Cheers :)
Manifolds come with gasket sets too.
Need to sell by Friday next week...or taking them off the market.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2437074
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
