- Original GTR32 Strut tower brace
(Black ends with silver centre bar excellent cond.)
Make an offer!
- Original GTR32 floor mats (in good condition)
Make an offer!
-Apexi twin pod filters (done 2,000ks if that! as new)
$325 ono
-VOLK RACING 18" rims (AS NEW, silver with polished writing
$2,500 no tyres
- 3" mild steel cat back exhaust (super cat stainless muffler)
$450 ono
- HKS type 1 TURBO TIMER (has 0-100 timer etc includes harness)
$300 ono
- 3" cat pipe
$50.00 or case of beer :uh-huh:
PM me...
I might be interested in a few parts.
Will the strut tower fit if I have aftermarket (Tein) suspension?
Do the pods have the adaptors to fit an R32 GTR?
And does the turbo timer have the wiring harness/adaptor for R32 GTR? And also does this turbo timer remove the speed limiter??
thanks,
Andrew
YES
YES, FULL KIT + INS
YES
NO and I don't know of ANY that do!?
All the bits just came off my 32GTR before I traded it!
YES
YES, FULL KIT + INS
YES
Thanks for that mate.
Im more interested in the turbo timer than the other parts.
I think there is 1 turbo timer that does remove the speed limiter, a blitz one i think from memory???
Anyway Ill get back to you real soon about the turbo timer (if its still for sale)
thanks,
Andrew
I saw the picture after I posted. Just stupid and lazy on my part.
I'll give you $100 plus shipping, direct deposited into your account before you ship.
you can call me or email me if you like
[email protected]
0411 471 684
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
