HI All,
I just got the wireless adapter for my 360 and must say am very impressed at the improvement of xbox live performance. My signal strength is pretty low due to the location of my router etc but still i can play game on live with minimal problems, played pgr3 and world cup 06 yesterday and it was great.
Also the ease of use and ability to use the 360 as a media centre extender is great.
Cheers Stink
https://www.sau.com.au/forums/topic/131661-xbox-360-live-wireless-performance/
Same, i bought XB360 and wireless adapter yesterday, had it all up and running in less than 10mins, and not an issue with my router. The speed is sweet i can stream mp3s from a pc and still be on xboxlive in PGR3. ;)
cheers
Evil
Most definately on the expensive side :rolleyes: but it allows me to move the xbox anywhere in the house and not worry about cables. Not worth $180, but a decent pci wireless card is around the $120-150 mark anyway.
cheers
Evil
Yeah for what it supports it a good little adapter, like evil said you will pay close to that anyway buying something else. I got mine for 159 from target.
When buying an IT hardware you should always check for compatibility with your existing gear, its a given!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
