Just a quick q got a cat from the Batmbl group guy and was wanting to install it myself?
which way does the cat go with the 02 plug at the front or back?
Cheers
O2 sensor goes to the back, passenger side.
Check out the DIY thread, it's got a full run down on the process that's pretty good.
https://www.sau.com.au/forums/topic/131752-catco-cat/#findComment-2440769
Cheers
Its actually not an o2 sensor. It is an exhaust temp light sensor.
ie. when the temp gets toooo high, the exhaust light on your dash just lights up.
Really does nothing.
The o2 sensor goes where the dump pipe is, after the exhaust end of the turbo.
https://www.sau.com.au/forums/topic/131752-catco-cat/#findComment-2440846
