Hi people.. I had my dump pipe off the other week putting on a split dump pipe. I was looking up at the exhaust wheel, just checking all the blades were there etc... I spun the wheel with my fingers and it didnt turn for very long! I made a noise like a dry bearing noise :laugh: and the shaft had bout 2mm ruffly in and out play! is it shagged? :rofl: anyone know? :D
https://www.sau.com.au/forums/topic/131915-how-much-shaft-play-is-ok/
if it was shagged it would probably make jack all boost, chop when coming on boost and make wierd bearing noises. when the car is off the oil line isnt flowing so it probably wont spin as well as it would with optimum operating temperature and a flowing oil line to lube the bearings.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
