i no this is a skyline forum and all but i need some possible explanations
my wheels is a x3 excel SOHC and im having some probs with it
everytime it is under load - ie going up a hill, it shudders in 3rd and 4th gear (around 50-80km/h)(shuddering like its running on 3 cylinders, barely any acceleration at all uphill even with foot flat on floor)
and sometimes in acceleration from standstill
sometimes the check engine light comes on, sometimes it doesnt
sometimes after driving it will idle really rough - like it is running on 3 cylinders or somefing
my mechanic says that it is a fuel prob as it blows blue smoke out the zorst when it does this (and only when - so its not burning oil - phew)
but being a poor uni student and all i dont want to have to spend buckets loads finding out what it could be
as is ive changed the fuel filter (as it needed to be done anyway), changed spark plug leads(as they were really rooted), swapped the ecu(bugger of a job), checked my spark plugs(they are correctly gaped - although i should get some new ones), injector resistance is the same across all four, ive run it on a tank and a bit of premium, used fuel injector cleaner and all of these to no avail, although it seems to not shuddering as much going up hill now
what could it be?
i should get a diagnostics test done but cant be bothered :)
and it does need a filter and oil change and a tune
coil packs? spark plugs? injectors?
any helpful help would be appreciated
https://www.sau.com.au/forums/topic/131929-engine-gurus-help-needed/
if you are trying to go up hills in a excel, at 50kmh, in 3rd or 4th gear, id say your engine is pinging itself to death. Little engine need higher revs than itll be pulling to make the power to get up hills, bud.
ummm blue smoke IS burning oil... BLACK smoke is burning fuel, so id see a different mechanic to be honest...
PS work on your basic grammar and spelling before you next take it to a workshop. If you come across this unintelligent in front of a mechanic, mate, id say he may be taking you for a ride.
well it needs an oil change so i'll do that and check the smoke then
but it only smokes when it shudders and rough idles - no other time
and maybe i didnt get a proper look at the smoke but it was smoking non the less
and i trust my mechanic so....
i realise it needs revs - what i mean is that it willl start shuddering sometimes in 3rd, sometimes in 4th, and anywhere between 50-80km/h is when ive experienced it
(one situation it will start shuddering just as i change into 3rd going uphill and slowly accelerate until i change into 4th and then leap and jerk its way through 4th up to about 70-80km/h then it is all fine again)
ok well try keeping your revs a bit higher, mate. like i said, those engines need more revs than you are giving it. You are making it work too hard, trying to pull that car up a hill. If you are in 4th as you are speeding up to 70-80km, uphill, then you must be changing into forth at about 50...
dude its not a diesel tractor.
try this - 1st gear til about 25-30. 2nd til 45 or so. 3rd til about 60-65. 4th til 80, 5th from there onwards. Less than that, your car just isnt gettin enough weetbix to muscle up hills. Thats whats making it jerk. You need to change your driving style. Itll be pinging itself to destruction, and id say you having been causing damage to working parts by driving it like you do.
Does it smoke when you jerk? (sounds bad, lol) I wouldnt be suprised if the jerking is just you dumping the clutch on it trying to idle up hills, and the smoke is from a different problem altogether.
Those lil engines can take a lot more revs than youd be feeding it (sounds like you are trying to go uphill, in forth, at about 2000rpm....), the reason being because they NEED to.
  • 1 month later...
if ur interested the problem is fixed
one of the wires from the loom had rubbed bare under the dash and was earthing itself out
under load it was too much and it would run on three cylinders - hence the shuddering
here i was replacing injectors, fuel filter, air intake temp sensor blaa blaa blaa
all good now and hopefully my fuel economy goes back up too!!
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
