Hi Guys,
Decided to sell my wifes R34. Located in Melbourne.
1999 Nissan Skyline R34 GT-X
- Pearl White
- 87,000 km's
- Tiptronic
- Dual Airbags
- Custom Dash Surround/Centre Console and Arm Rests
- ABS
- Pioneer CD/MD Player
- Keyless Entry
- 34GTR N1 water pump
- Z32 Fuel Filter
- S15 Rear Stabiliser
- Nismo front lower arm
- R34 GTR master cylinder
- 2Way LSD
- Tanabe front tower bar
- Nismo Clear Indicators
- 17" Rays Nismo LMGT Wheels (17x9 front, 17x8 rear).
Immaculate Condition, No accident History, Genuine Kms, Timing belt has been changed, Comes with service books from Japan. Car will be sold with 17" Rays Nismo LMGT Wheels. R34 GTR wheels not included
$16,000 with above mods
$15,500 without Suspension - Rock bottom price, no offers, no swaps, no nearest offers - firm price - needs to go, thats bloody cheap !!!
https://www.sau.com.au/forums/topic/132126-r34-gtx-extras-galore/
  • 2 months later...
  • 1 month later...
Recaro Seats will be going this weekend and replaced with factory GTX seats. I have also put 17" Nismo LMGT (White) wheels on it.
Will take some pics this weekend hopefully.
Price is now $15,500 without RWC.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
