ok i have just finished my car as i posted before, its a breeze to drive the 50 km to work on a nearly empty freeway with nearly 600HP at the wheels. but i have bought a fully stocker of a engine from a friend of mine he bought the enmgine in japan and shipped it over to me. the engine is complete with loom and ECU. i have been looking to the engine and have been thinkin, to keep the engine as is in case somthing happens to my race engine, or the fiddle with it and prep the car for the shit faced dragracers in my country as there is some dude with a menacing 800 WHP RNN14 pulsar. if id go through with building my engine id go the following way: HKS step 3 stroker with 2.8l dicplacement, Tomei englared sump. maximized porting and use tomei procams at 11.35mm lifth with 280deg IN and 290 deg out, manly genB 1mm oversize valves, combustion camber reshaping titanium retainers etc. a Trust T88H-34D turbocharger with a custom exhaust manifold and a HKS 50mm external wastegate, a MOTEC ecu, 5inch dump pipe my intercooler will suffice HKS harmonic balancer etc. OS GIKEN cross mission gearsets, uprated driveshafts and 14 inch wheeld with mickey thompson slicks :).
is this the way to go, my aim with this setup is a menacing 950-1000HP vehicle that will make any RNN 14 shit bricks. the monay to get these parts is not here but a few months of savings will be enough to start buying some of this stuff.
https://www.sau.com.au/forums/topic/132629-drag-monster/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
