Gb: R32, R33, R34 Skyline Carbon Fibre And Fibreglass Bits
  • Replies 272
walkoau; will break their legs for the answer today!
Rflirty4; eyelids are plenty :)
Nightcrawler has confirmed 1 of the 2 bonnet lips so we are down to 1 at the moment.
Thanks all
Stan
PAV34; yes but really cannot be assed to get it sent over
vinci68; will check
Also; if you're reading this can Andrew who has made a payment this morning please post up here (stupid me forgot to ask for a forum name on the email)
Thanks
Sorry Samantha; must've forgotten - been so busy trying to get everything all lined up.
Well now you know; it's available... would you like a PM?
Yes please :O
(the total including shipping)
Current Confirmed Order:
2 x FG Bonnet Lips
3 x FG Eyelids
1 x CF B-Pillar Moulds
NOTE: There are NO MORE FG Bonnet Lips for the R34GTT until further notice.
Only 1 more set of R34GTT CF Sills left; probably for quite some time or at this price.
Couple more orders waiting for payments then I'm going to close this order and send the funds to the supplier!
any updates/price on the CF bootlid?
i 2nd that.....
stan thats 3 ppl now interested in the CF bootlid.
thanks
Justin
OK; today is the last day of grace for anyone who hasn't confirmed payment / paid. I will be finalizing the amounts tomorrow morning and sending the money off. Heaps of people have said to hold up for them but it's unfair to those who have already paid from day 1 - you're going to have to jump onto the next order.
Thanks peeps!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
