Group Buy # 2 Arospeed Adjustable Cam Gears
  • Replies 223
Posted Images
How do these compare to Tomei duralumin ones? Are these harder or softer as durable?
Are hard anodized ones harder than nickel plated?
Does it make any difference in the long term or for very big power?
I'm interested in an R33gtst exhaust one.
Not sure against tomei, but these are hard anodized and are 7075 aluminium.
Not sure also if harder than nickel plated, i dont any cam gear is nickel plated as nickel fakes pretty easily.
Put me in for a RB25 exhaust one in blue please.
I thought duralumin was two times harder and four times as heat resistant or something? But the price is right and sounds like it is suited to the job.
Edited by Edge
Guys been busy, so ill do it by 2morrow, im going out now.
Also no gears for subuaru only skyline sorry.
Hi r33kid,
I have also paid and had no conformation update,
Can you confirm.
Cheers
New Update
1)NV N01 * IN FOR A PAIR PAID
2)MUCK * IN FOR 1 GEAR
3)Lazy-Bastard * IN FOR 1 GEAR PAID
4)fredzz32 * IN FOR A PAIR PAID
5)robbo33 * IN FOR 1 GEAR
6)Cillham * IN FOR A PAIR
7)Kinell * IN FOR A PAIR PAID
8)XZLA.8 * IN FOR 1 GEAR PAID
9)frother * IN FOR A PAIR PAID
10)BAMR33 * IN FOR 1 GEAR OUT
11)DJRIFT *IN FOR A PAIR PAID
12)jnr32 *IN FOR 3 PAIRS
13)dead32 *IN FOR A PAIR
14)Frank rb25 zed *IN 3 GEARS PAID
15)kjb_r33 * IN FOR A PAIR PAID
16)DRKSKY32 *IN FOR A PAIR
17)jeffworld2 *IN FOR A PAIR PAID
18)Angry *IN FOR A PAIR
19)Freddy Kruger *IN FOR 1 GEAR
20)JaFF * IN FOR 1 GEAR
21)Ruffels *IN FOR A PAIR
22)RANDY *IN FOR 1 GEAR
23)stR33ter *IN FOR 1 GEAR PAID
24)woolls *IN FOR 1 GEAR PAID
25)phatboi2010 *IN FOR A PAIR
26)rza1 *IN FOR A PAIR PAID
27)Edge *IN FOR 1 GEAR
28)Turbz_13 *IN FOR A PAIR
29)aquariuz6 *IN FOR 1 GEAR
30)SXY *IN FOR A PAIR PAID
31)ls1ben *IN FOR 1 GEAR
32)Mike_ *IN FOR 1 GEAR
33)Lionel s *IN FOR A PAIR PAID
so far 57 gears.
PLEASE NOTE FOR THOSE WHO HAVEN'T PAID , PLEASE DO SO BEFORE THE 10TH OCTOBER, IF WE DONT GET ALL PAYMENTS THEN PEOPLE THAT HAVE PAID MIGHT NEED TO PAY EXTRA.
Edited by r33kid
Yeh i don't want people paying more as it complicates things for me.
People who haven't paid / money hasn't cleared as of today.
Ive sent all a PM some have replied others haven't, i just need to know who is in or out.
18)Angry *IN FOR A PAIR OUT
Edited by r33kid
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
