Closed
310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
@GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
