Is it an AVC-R? It seems to me that it a few mm too big to fit in there. I've got mine where the ashtray was but obviously that's not out of sight.
My PFC hand controller just floats around and ends up under the passenger seat a lot. Maybe you could do that. The cord is long. Maybe have some mount that it easily slips out of then you can slip it under the seat or into the glove box whenever you need to.
you can do it, i've seen it done a few times and planned to do it myself, abo bob is right, its a little to big to fit in so you have to cut a hole in the top of the din pocket and slide the avcr down into it. I made it work but never got around to fitting it. I've left it in my glovebox (also to hide it). Too much of a hassle cause i have double din headunit and can't be bothered buying a new one.
Yeah i've done it (but the sin din pocket with Lid is from a X-trial, becoz r33's dun come with em standard)
With lid closed
With lid open to adjust boost settings and check max boost reached :D
1. The Avc-r will fit BUT its too tall for the pocket so you gotta make a hole in the pocket to have a bit of the avc-r sticking out, BUT as you can see once its all in it fits perfectly you don't miss out any of the screen and it doesn't hit the air-con or cd player.
2. So start CUTTING! hahaha
Good Luck!
now im spewn, i bought an orig r34 pocket & the lid only goes 3qtrs down. i hope it wont be too hard to fit.
i do like the sunvisor idea.
Gtshortie - thanks for the pics
cheers
steve
why dont u try putting it in the pocket under the headlight adjustment......u no wat im talkin about yeh?>??
cant explain it very well but its like right next to the steering wheel on the right.
according to the engineer when i had my car certified, technically the AVCR is legal, as all it does it slightly alter the amount of boost you get. The same effect can be given (albiet to a lesser extent) by driving in Blue Mountains one day, and Sydney the next (elevation / air temp) apparently.
well i got a canary for it when i got pulled over. They said that you are unable to have any adjustment to the emissions control of the car. and a boost control does that. "apparently".
any excuse to stop imports from allowing there full potential. in victoria.
cheers
steve
Sorry guys i forgot to say that my lid only opened 3/4 as well, BUT someone accidently dropped something from the windscreen and it broke the lid off so now i've got velcor holding the lid on.
its good to see the boost peak, to make sure there's no spiking.
also once its tuned ill have 3 settings, low-mid-hi.
i know what u mean as i never change it now, but once its tuned it will probly be changed a few times. at the set of lights next to my mate in his wrx or when i take it down the qtr mile etc.........
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
