For 4door skyline r33 series 2 seem to have dual fillament bulbs, though I havn't pulled them out yet on the 4dr the headlights are not smooth but refractors instead. High beam comes from the same bulb spot when looking from the front.
4Dr S2 Skylines uses H4 bulb.
So when buying HIDs for H4, either you buy H4 Hi/Low HID which will cost more or u buy those with HID Low Beam and Halogen Hi-Beam.
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2547095
  • Replies 66
Can anyone confirm if these are exaclty the same as kaixen xenon hid lights.
I doubt they are the same as " Kaixen " hid kits, the Kaixen kits go for MSRP: $599 but I’ve seen them from a SAU business trader for $399inc delivery.
For a HID kit $220 is pretty cheap, the lowest price for a kit i've seen is $190 delivered which would take at least about a week to get to your door.
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2547662
What sort suits s13 silvia headlights? Low beams? The ooo ooo style headlights? If you can find out for me - put me in for a set of 6k:) Thanks.
I'm in the same boat as you buddy,
technically to you need a H3c light bulb but their very rare so what i've been told to do is get the H3 and fit it in there very easy, seen it done to my friends 13.
i am buying one of these kits
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2553420
well blew one of my low output "blue" globes which i cant see shit ahead of me tonight, pretty pissed off actually seeing as they are only a month old...
Does the warranty cover globes? how hard are they to get and how much?
Answer those and you might have another buyer on your hands...
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2554632
Hi guys,
I am interested for a set of HID , and i have no idea what these codes mean..from reading on..i guess 6000K is good..but i want brightness and bluness at the same time?
please suggest and will these fit onto my GTR33?....plug in?
Thanks
Please answer the questions?
Do you have a moderator or admin who can vouch for your character?
Are you a member of any of the forums clubs? (ie. QLD, NSW, SA, WA, VIC)
What do you mean pm you with the details...
Your controlling the group buy, your giving us the details.
Dont use pm's at all in a group buys as it makes it look very sus.
What do you want to hide from the users of this forum.
You need to earn our trust not make us ask questions about your intentions.
Dont take this to heart im just trying to help you get a good trader rating and secure the best for the forum users in general.
Cheers Col
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2557131
bulbs are covered under the warranty they come in from over seas and they are not hard to get
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2558808
OK so then I need H4 bulbs. I'm going to want 4300K.
Nismo15 - Which ones for this price? Would I get High/Low HID?
Last question. Who do we go to for that 1 year warranty?
Edited by Edge
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2562565
for the h4 the low beam is hid and the high is halogen you can get both but they are much more expensive
for warranty i will give you the detail of the guy to call if anything happens
https://www.sau.com.au/forums/topic/134840-hid-kits/page/3/#findComment-2562735
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
