Boost peaks @ 16psi then drops to about 13psi. Best run was [email protected] but it was a street meet so i broke out, dialled in @ 14.3. I think it may have done a 13.99 by the end of the night if it was a test 'n'tune & could have got more runs in. STUPID me changed into 5th before the finish not thinking
(4th is good for about 180kph) so it may have ran 100mph as well, best mph was 99.8 when it was still daytime. Chiptorques dyno reckons 121kw @ tyres.
Another vote for Rob Bliss here. His shop did my exhaust about two years ago and it's still going strong :)
Only change needed was to cut the centre muffler out as I wanted more noise, and I had the guys (at a shop in Toowoomba, where I was staying at the time) weld in a couple of flanges.
Slightly OT, but they also made me a track-only pipe that eliminates the cat and exits under the passenger seat, it's really loud :P I dunno whether it makes any more power but geez can you hear the turbo spool! :D
My opinion is to fully check out the shops work. If you see an exhaust that you like ask the owner. I got stung with my IC pipes big time shop will remain nameless but they were in the list. I had to redo pipework for the following reasons I had a oddysey battery which he was aware of yet he ran pipework past the positive battery terminal (the battery terminal had cover on it) as the battery sat on side the pipework thumped against battery posts causing internal breakage. pipework rubbed on bonnet and together. pipe to throttle body blew off on dyno (dyno operater guessed who did work even when I refused to tell him who did it!)and final insult was a shit tin pod filter replacing a 1 month old K&N panel filter (which is now in ol' man's navara) cost was $600 for export paint painted pipework. My mate and I redid all of it ourselves had it HPC coated piping for around $300! Please don't fall in same trap I did!
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
