hi anyone that can help me i want to get my non turbo R33 Turbo'd i was hoping to see if anyone has done this before and where they got it done and for how much ..... any points in the right direction would be great thanks guys PM me or just reply to this or my email address is [email protected]
THANKS
https://www.sau.com.au/forums/topic/136065-i-want-to-turbo-my-skyline-r33/
THANKS
You would be far better off selling you current car, and buying a turbo R33. The conversion will cost $3500 minimum. And you will still not have the larger brakes, and five stud hubs of the turbo model.
My car started out life as a R32 GTS25 (non turbo RB25DE)... I now have a RB25DET engine, R33 brakes, LSD, new clutch, computer etc, etc - I'd hate to think what it has cost me all up. But the far smarter option would have been, to sell my car and buy a R32 GTR.
THANKS
hahah gimmie your ute ill help u
THANKS
i have done this conversion on a few occasions and be done on a shoe string budget. find someone thats selling there stock set-up, turbo, manifold,piping etc, should be able to pick up all parts needed for under $900. do the work yourself and save yourself a few dollar. dont run more than stock boost to be safe.
who gave u price 3500$?
It cost me a fair bit more than $3500, but for what I've achieved - it's been worth it.
The minimum $3500 I was referring to, was to purchase a RB25det front cut... and get the complete Engine, Loom, Computer, intercooler etc, then drop it in...
I didn't consider slapping a turbo onto the side of my RB25DE, as I wouldn't have been able to gain the power I was after. You'd struggle to make more than 160rwkw safely with the 10:1 compression, on top of that, there are also the limitations of the RB25DE injectors and computer. In my opinion you'd be far better off buying the turbo car, and gaining all the good stuff in one hit, than trying to dodgy up a turbo conversion.
If he sold the R33 GTS for around $12,000 - then purchased a R33 GTS25t for $16,000... He would have gained a RB25DET, loom, computer, intercooler, bigger brakes and wheels, five stud hubs, LSD etc... for $4000.
And you wouldn't have to worry about getting booked by the cops for having a turbo conversion on a non-turbo car... not to mention the insurance trouble you would have on the modified car.
i think the guy just wants to turbo his RB25DE engine not sell his car.
go the conversion mate, it will probably go better than you think as 10psi and hi compression go alright for the cost.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
