they look like big toyota 4wd's.
Lol go into the Group buy section and get some shocks to drop them a little bit.
haha only joking man, mine looked high as hell like that once.
Edited by The Mafia
  • Replies 249
heheh i think all our cars were stock height at once!!
But nah looks good dude..
Btw if anyone wants to sell there series 2 bar in silver, i will buy it ASAP!!
Cheers..
Yeah, I love the P1s too. And the fact that they're really light sealed the deal. The Work Equips have a MUCH better offset though, 17x9 +20 all round. Stick out the guards about 20mm all round, flared the guards a fair bit and they're pretty much in the guards now.
Put the P1s back on ya car! :)
Im selling my wheels.. anyone interested? Its WORKS wheels! Looks good on any colour 33's, specially on black.
Fronts are 8" with 225 rubber, Backs are 9" with 255 rubber.
Edited by Janissary
Ferah what mesh type rims are on your old car??
Janissary-- think you posted your ad in the wrong place!! If it was silver it would have been alright i guess..
btw nice colour car!!
but yea try in for sale section!! You will have more luck there
cheers..
Very nice Mr Crust.. Rims were next on my mods list... but i dont know now..
Rims or Full turbo back exhaust.. (including batmbls Dump/front pipe and high flow cat)
decisions decisions
p.s. What side skirts are they crust?
Edited by MotoMan
  • 4 weeks later...
Over the next few days I will update some pics of my car!!
Well i resprayed my rims.. :/
The BEFORE shot: (got two more rims to spray up and i will post some pics)
Edited by siddr20
