got some stuff i wanna get rid of so i can fund the rest of my cars build.
all items are in sydney
reason for sale is i wanna go twin high mounts on my RB30
1. custom high mount manifold - $300
provision for external gate
suit RB20/25
T4 flange
2. T70 turbo - $600
this is not a dodgy ebay job that will fail the first time you run it
its been run for 5 hours and made ~250rwkw and still had heaps more in it
i was half way through smoothing off all the casting marks etc from the front housing
to get it looking perfect before getting it polished
i can get it polished for an extra $100
3. X force 3" polished stainless cat back exhaust - $400
no rear muffler
brand new still in packing
suit R32 skyline
no its not a trust turbo i never said it was a trust turbo
it wil still make ~300kw no problems the guy i bought it off uses quite a few of em and swears by em
it looks identicle to the ebay one,right down to the little mark in the centre and the plate that lets you know its a "turbocharger"
where is it made?
the top pic is a pic i had on the computer of a similar one
the bottom one is the actual turbo
i bought it from Dr Drift off here, it may be off ebay im not sure
but as i said its not one of the ones that dies as soon as you run the car because this one has been used before with great results
Hey mate,
i think all those turbos are the same xs power ones. i bought one from a well known drift shop in qld and compared to one from ebay there identical. i used mine with some good results but then....im not going to comment anymore just thought i would give you a heads up.
does it say XS power on it? no it doesnt
does it say master power on it? no it doesnt
does it say any other brand like all the other dodgy ebay ones? no it doesnt
if you want ask the guy i bought it off and see how many he has used and see how many have failed
he'll tell you hes had 100% success rate with these turbos
and hes not a dodgy guy either hes been on SAU for a long time
how about this
ill give warranty with it
if the turbo doesnt work or fails after 30 days ill give the buyer their money back
  • 1 month later...
how about this, 600 for turbo and manifold.
The manifold.....will that suit the turbo or is the turbo a T3 flange?
may be keen to buy.
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
