Evan is leading the charge - he'll be in the hood some time around 6.30pm
Steve McQueen and I will be there aboot 7pm
Evan is going to SMS me where he sets up camp - I'll let you know when I know
https://www.sau.com.au/forums/topic/136843-beerfest/page/2/#findComment-2548908
I am so inspired.
What a fabulous movie. I think it must be mandatory viewing.
"I show you how to drink a beer, mother f*cker! "
You know - there was no need for there to be boobs in that film... and yet, there were boobs in that film. That's how great it was.
https://www.sau.com.au/forums/topic/136843-beerfest/page/2/#findComment-2550947
i would put that down as the best movie all year
was great and even the girlfriend loved it
thanks again james for setting it up was a great night
wish i could of gone drinking but you know work BOOOOOOOOOO
https://www.sau.com.au/forums/topic/136843-beerfest/page/2/#findComment-2551341
correction :laugh:
Barry Badrinath: "Wow! This shit is great! I wish I could freeze it, and make ice blocks out of it, and then skate on it! Then, in the spring, melt it down and drink it!"
Otto: "Ya it looks like his head is covered in pubic hair [laughs] but it's ok it works, ya, cause you've got a dickface"
Fink: "I show you how to drink a beer, mother f**ker!"
But the classic is.......
Landfill: Real funny, Deutschebag.
https://www.sau.com.au/forums/topic/136843-beerfest/page/2/#findComment-2554978
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
