well if you want to carry Bikes get one of the Saris "Bones" racks, they strap on the boot, no tow-bar needed, fits over the rear spoiler and doesnt damage the car at all, uses rubber feet supports.
I have run 3 heavy down hill rigs on the back and have no problams at all... better than getting all the mud and crap on my back seat :D
They can fit up to 4 bikes and cost about $300.
