Hi everyone!
Can someone please point me in the direction of an extrude honing service in Adelaide?
They are quite elusive, white and yellowpages search didn't come up with the goods.
The only company that I can find on the net is Abrasive Flow Engineering in Sydney.
I hope someone can help.
:D
https://www.sau.com.au/forums/topic/137096-extrude-honing-in-sa/
In case anyone is interested, I was just quoted $650 from Abrasive Flow Engineering to extrude hone my standard RB25 exhaust manifold.
They told me they have done them before, and have increased their flow capability from ~130cfm to ~170cfm.
Not a cheap exercise! Nuts :no:
In regards to my setup, since it is the only part of the exhaust tract that has not been modified (ie. enlarged), I'd expect some power gains, how much remains to be seen.
Say you have a setup with a standard exhaust manifold that is pushing the turbo to its limit at the top end, with boost falling off near redline, would this mean that most of the gains from extrude honing be made in the midrange?
What do you guys think?
Cubes, like anything, they are good up to a point. They are certianly good for response. Either way by getting an aftermarket one you are only gaining say, 5% power at the very best so value for money aint there and you have to deal with the tradeoffs (heat/not stock looking/worse response for equal lengths etc).
Turbo Tits, if boost is falling away its more likely the compressor is running out of puff. The manifolds increase the engine's volumetric efficiency, rather than the turbo's capabilities. There might be some gains to be had on the midrange but who knows... Remember you can have the primaries as large as you like but the exhaust pulse still has to squeze thru the relatively squashed turbine housing. Sorta like a storm drain with a garden spray jet on the end.
Just a quick update.
I got in touch with Andrew from Specialised Power Porting in Victoria. He's asking $550 for his extrude honing service. Sounds like a great guy, really helpful and willing to chat.
General turnaround time is 2 weeks. But he said if you call a few days in advance and let him know when the manifold will arrive, he can pencil in into his workload and can have it done in a few days.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
