Hey all,
I used to go to the coast a hell of a lot but in the last couple of years i've been about twice. And now that i've got my skyline it gives me a chance to head down in something decent. I don't know when this would suit all of you so maybe if your keen post it up and we could try work something out.
Maybe someone knows of a really nice beach that has BBQ facilities that we could have lunch at.
Also an area where snorkelling is really good if people have the equipment??? I dont know but throw in your suggestions and lets see if this can work.
:D:)
People attending the coast cruise on the 2nd of December:
Sauce
Frink
georgia
R34-GTT
Sigsputnik
Mik_R33
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/138006-coast-cruise/
I'll be in if I don't have uni or work on.
We used to have a place down on Merry Beach which was awesome. It's located half way between Batemans and Ulladulla. Don't think there was any BBQ facilities near the beach though.
https://www.sau.com.au/forums/topic/138006-coast-cruise/#findComment-2569029
Thats north of Ulladulla isn't it? That would be a nice drive up the coast from batemans.
South of ulladulla...
go thro Batemans bay, past surf beach, past malua Bay, past Marouya past turros and just after Dalmeny.
bout 50mins from Batemans bay..
EDIT: depends if you were talkin about Narooma or Merry beach
Edited by SkyGTRline
https://www.sau.com.au/forums/topic/138006-coast-cruise/#findComment-2569474
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
