Ok well for the people who think they can come put your name down for saturday the 2nd of December and ill post them up in the first post. Once everyone is done we'll see if there is enough to make it worth while, and when we figure all that out we'll choose a destination and the rest of it. :teehee::)
Edited by R3sp3ct
Hey guys,
Seeing as that Xmas cruise is going to happen around the same time as the coast cruise i feel it would be best to postpone it till early next year. If all of you who have put your name down are still keen for this on the 2nd then post it up but otherwise we'll give it a miss for a while. I wanna go but not if ill be on my own.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
