1989 toyota corolla sx 100kw 4age 149xxkms just service about a mouth ago ,has a full zorst with canon ball , extractors, stock wheels, red seat covers lol,big system eg kicker square sub run a 800watt rms amp and also another amp running the slips front and back and top of the line alpine deck, the set up is worth quite a bit and been tolled when it is tune it should have a bout a 150 db , new battery, very good on fuel like about 500kms to
A tank and is quite a quick car for what it is and I have never had a problem with the car other than a flat battery but it has been replaced with a new one ,the body of the car is ok
For its age the only thing wrong is there is a bit of damage to the back driver side of the car but I don’t think it will cost to much to fix I was going to try fix it my self but have had no time eg work gf, other than that the car is fine and drives like a dream the only reason I am Selling it is I wont to get a luxurious car eg Lexus.
I am asking about $6,300 neg with every thing or 5,500 with out deck ,sub,amp and ill put in a different deck
in with the car.
If you need any more info feel free to give me a call on 0410727690 also the car is
In syd.
ill get some more pics up soon just need to give it a wash
Edited by gtr2env
https://www.sau.com.au/forums/topic/138023-1989-corlla-sx-100kw/
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
